Smoking after ticking over for a while
  • toms dun
14 Jun 2012 20:22 #42358 by toms dun
Smoking after ticking over for a while was created by toms dun
I'm a new member found the site brilliant for info. but can't see anything on this please help
my jimny is "98 got about 120 th on clock
after warming up on maybe 25 - 30 mile trip if I have to wait on tick over at road works or traffic lights any length of time . when I then set of I get a white smoke screen as though aload of oil has been dumped into the exhaust the throttle also appears none responsive this has happened acouple of times now after 100 metres or so it becomes ok again
14 Jun 2012 20:41 - 14 Jun 2012 20:42 #42359 by kirkynut
Welcome matey!
Check your oil filler cap and dipstick for a white mayonnaise like substance and your coolant level. Might be water your burning to cause the white smoke from a blown head gasket.
I hope it's not but the mileage makes me think it is, especially if it's a single cam engine.
Last edit: 14 Jun 2012 20:42 by kirkynut.
The following user(s) said Thank You: toms dun
  • 247sniper
14 Jun 2012 20:53 #42362 by 247sniper
Replied by 247sniper on topic Re: Smoking after ticking over for a while
Check oil and water level and get back too us mate.
O... and welcome to the forum.
Steve.
  • toms dun
14 Jun 2012 21:10 #42366 by toms dun
Replied by toms dun on topic Re: Smoking after ticking over for a while
thanks for that have checked for yougert not found any although have been using a bit of coolant so think your right.
is it much of ajob on jimny Ive done disco and mini gaskets cheers
toms dun
14 Jun 2012 21:15 #42369 by kirkynut
I don't think it's too hard a job but it's a while since I've seen a single cam engine in the metal. I think taking the manifolds off and rusty studs is the worst part.
You must get the head skimmed or it'll go again!
  • 247sniper
14 Jun 2012 21:20 - 14 Jun 2012 21:21 #42371 by 247sniper
Before going ahead and strippping the head off, the first thing i would do is a cylinder leakage test just to confirm that the head gasket has gone.
www.google.co.uk/imgres?hl=en&biw=1366&b...o6z8QOR1KWmBA&zoom=1
This explains it better,
www.google.co.uk/imgres?hl=en&biw=1366&b...t:429,r:15,s:0,i:119
Might save you hours of unneccisery work if the HG has not gone.
Have you got or can you lend/do?
Steve.
Last edit: 14 Jun 2012 21:21 by 247sniper.
Time to create page: 0.091 seconds
