Fitting SJ Hubs on The JIMNY
  • apfriend
08 Jun 2012 20:27 #42001 by apfriend
Fitting SJ Hubs on The JIMNY was created by apfriend
I bought the adapters from the BigJimny Shop the other day, the came with longer bolts and spring washers.
I'm confused because i was told to make sure I got the cone washers with the SJ HUBS when I bought them.
So do I use both the Cone Washers & spring washers?
Help?! :)
Thanks,
Andy!
08 Jun 2012 21:30 #42010 by mlines
Yes, if you got the SJ Hubs that have the cone shaped holes then you need the cone washers to fill the holes properly and then use the bolts and spring washers to retain it all.
The following user(s) said Thank You: apfriend
  • apfriend
08 Jun 2012 21:38 #42015 by apfriend
Replied by apfriend on topic Re: Fitting SJ Hubs on The JIMNY
Thanks Martin, Much appreciated :)
Time to create page: 0.241 seconds
