Car beeping when drivers door open?
  • apfriend
05 Jun 2012 22:38 #41834 by apfriend
Car beeping when drivers door open? was created by apfriend
2001 JIMNY
1) UNLOCK DRIVERS DOOR
2) OPEN DRIVERS DOOR
****CONSTANT BEEPING STARTS****
3) KEY IN IGNITION AND TURN SO IGNITION ON - ***BEEPING STOPS***
Basically is this normal?!?!?!?!
  • Keefe
06 Jun 2012 05:47 #41838 by Keefe
Replied by Keefe on topic Re: Car beeping when drivers door open?
Hi,
Mine does it but the key has to be in the ignition. If the key is taken out, it stops.
Keith :-)
06 Jun 2012 07:32 #41841 by kirkynut
As Keith says it's either the broken beep of the keys in ignition reminder or it's the continuous lights on reminder that keeps going even if the keys are out of the ignition.
If it does it outside these circumstances and the car starts and all else is fine, lights are off etc, it must have gone wrong. I think the noise box for it is in the driver's footwell near the fuses and might just be unpluggable to shut it up! Cam Suzuki might be able to sell a good second hand replacement.
06 Jun 2012 07:33 #41842 by facade
Are the lights on?
It beeps with the drivers door open if the keys are in or the lights are on.
  • apfriend
08 Jun 2012 18:42 #41993 by apfriend
Replied by apfriend on topic Re: Car beeping when drivers door open?
I'm going to have a play with lights on / off etc tomorrow as its in my mates garage at moment.....
11 Jun 2012 15:01 #42177 by saxj
Keefe wrote: Hi,
Keith :-)
There is an easy fix for this. Pull down the panel below the steering wheel, and pull the plug apart that only has a single wire going to it.
Time to create page: 0.157 seconds
