Wheels
  • ooky_123
26 Feb 2009 20:30 #418 by ooky_123
Wheels was created by ooky_123
Ive just been given a set of 5 Daihatsu sport track, 15" wheels with good Dunlop All terrain tyres fitted.
The wheels spent a few months on an Sj before being committed to a shed for storage for 12 months.
Anyway, they are 5 stud, 15" wheels with 195 Tyres. The wheels are in superb condition and the tyres have around 10mm min of tread on them
Im wondering if these will fit straight on a Jimny or will I need a suspension lift? Ive read that although the studs will line up, they have a different offset. will this give me a big problem ?
  • bazwidajimny
26 Feb 2009 22:22 #419 by bazwidajimny
Replied by bazwidajimny on topic Re:Wheels
hi thay will fit with no probs tou wont need a lift
  • ooky_123
27 Feb 2009 00:18 #421 by ooky_123
Replied by ooky_123 on topic Re:Wheels
Thanks. Will order a KAP 2" lift tomorrow anyway.
Need to replace the front discs and pads, plus get the car serviced too.
  • tree fella
27 Feb 2009 21:43 #427 by tree fella
Replied by tree fella on topic Re:Wheels
AAAAHHHHHH STOP
195 is just the width of the tyre not the OD (overall diamiter) this is how 'european style'tyre sizes work:
195/75 r15 this stands for a 195mm wide tyre with side walls 75% as tall as the width on 15" rims
so the OD of a 195/75 r15 tyre is 195mm x 75% x2 =292.5mm(11.5inches) + 15"= 26.5" OD
but a 195/85 r15 is 195 x 85 x 2 =331.5(13") + 15"=28"OD
What does your OD work out as?
  • ooky_123
28 Feb 2009 01:47 #436 by ooky_123
Hmmm ok, time to bring Hubby in on this I suspect.
The tyres, when placed next to the vehicle are definatly taller ... about 2" I rekon. still, I assume that will only put the speedo and odometer out, so whatever speed is registered on the speedo will be less than that actually being done .... is that right ?
Ill get the tyre sizes and check tomorrow when we planned on swapping the wheels over.
I assume they will still fit under the arches anyway, as they have been fitted to an SJ in the past.
Watch this space !!!
28 Feb 2009 15:27 #442 by kirkynut
Replied by kirkynut on topic Re:Wheels
You're lifting it anyway and you've got the wheels and tyres anyway, sticl on em on see. Then you'll know for sure. If they don't work, you'll just have to change them.
I think the offset of the Daihatsu wheels may differ to Suzuki's but not significantly, hence why so many people use them. I think it pushes the wheel further out but I'm not sure on this so don't quote me. This can be a good thing in terms of stability but will put extra pressure on wheel bearings.
Put them on and see and let us know!!!
Time to create page: 0.162 seconds
