Rear brake cylinder question
  • markyp2000
03 Jun 2012 19:07 #41702 by markyp2000
Replied by markyp2000 on topic Re: Rear brake cylinder question
5 must be the silicone stuff
  • ZookFastback
04 Jun 2012 11:48 #41728 by ZookFastback
Replied by ZookFastback on topic Re: Rear brake cylinder question
Yes, Dot 5 is the silicone stuff. I use it exclusively in my Classic/Vintage car collection as Dot 5 is Hydrophobic. Since the old cars don't get much of a run the silicone-based brake fluid protects the steel parts from rusting and if you spill some it doesn't stuff up paint. Most of my pre- and immediately -post war cars are painted with Vitreous enamel and they need to be protected. If using Dot 5, all previous brake fluid must be removed as they are incompatible, silicone and polyethylene glycol. Also, gotta make sure no air enters with silicone as it is absorbed and will lead to failure or at the very least, sponginess.
[IMG
  • markyp2000
04 Jun 2012 17:55 #41742 by markyp2000
dot 5 silicone fluid isnt Hydrophobic normal dot 3 4 5.1 is plus silicone has a lot lot more higher boiling point well thats what i was lead to belive
04 Jun 2012 18:32 #41747 by facade
Doesn't a hydrophobic fluid cause problems if there are any water drops in the system, with no way to absorb them they can just lie around and corrode?
  • markyp2000
04 Jun 2012 19:41 #41755 by markyp2000
facade wrote: Doesn't a hydrophobic fluid cause problems if there are any water drops in the system, with no way to absorb them they can just lie around and corrode?
hydrophobic means adsorbs water silicone repels water i think
  • Smoggy
04 Jun 2012 21:22 #41756 by Smoggy
Replied by Smoggy on topic Re: Rear brake cylinder question
I thought hydroscopic meant it absorbed water?
Time to create page: 0.461 seconds
