Buzzy Snare Sound
28 May 2012 17:31 #41292 by Halford
Buzzy Snare Sound was created by Halford
Just started .... buzzy snare type sound happening more and more, mainly at around 3000 rpm when taking boot of accelerator ... sounds like it's under my seat (exterior obviously).
any ideas
will be checking it out on Wednesday, just wondered if anyone had experienced it before.
:unsure:
  • markyp2000
28 May 2012 17:54 #41295 by markyp2000
Replied by markyp2000 on topic Re: Buzzy Snare Sound
probably the exhaust heat shelds neat the cat use a jubilee clip if the clamps are broken
  • Dutchjimny
28 May 2012 20:11 #41311 by Dutchjimny
Replied by Dutchjimny on topic Re: Buzzy Snare Sound
Im noticing the same since ive installed my replacement air filer.. my CAT heatshield is long gone so that aint the problem
29 May 2012 04:16 #41333 by Halford
Replied by Halford on topic Re: Buzzy Snare Sound
that did cross my mind - the coiled wires on the K&N's is a bit like a snare drum setup :huh:
will check it out wed and give some feedback
29 May 2012 06:33 #41335 by robs5230
Replied by robs5230 on topic Re: Buzzy Snare Sound
i have this sound intermittently . it has been suggested on a recent post that the dust shield behind the brake discs may be catching the disc. like i said it happens on mine intermittently and only for a short while, generally going over a bump in the road stops it. ?????????????
standard jimny - for now
The following user(s) said Thank You: Halford
  • goatboy
29 May 2012 10:54 #41348 by goatboy
Replied by goatboy on topic Re: Buzzy Snare Sound
sounds like heat shields on the exhaust to me. If its a suzuki exhaust it has heat shields on the Cat, centre section and back box (back box is like a plate on the top so hard to see with the exhaust on).
All of which can rattle and be quite buzzy at the right revs, I know because they have all rattled on my car....
