Speedo stuck on 50mph & No 4x4 light /drive
- apfriend
facade wrote: Get the first ones with the split handle that says "AISIN", everyone reckons they are the best type. Just make sure that they come with all the cone washers and fixing bolts.
Plenty of guides on stripping them down to clean them out.
The only problem is the body is chromed, and rusty, and nothing will stick to the chrome for long (not even etch primer
I could get the body's of the AISIN chrome one's chemically stripped / grit blasted at work.
I presume they strip completely down to just the cases/shells?
Cheers
- vitara_mad
just a bit of advise if you decide to remove the speedo sensor on the transfer box drain the oil first or it will be all over your drive
They do.
Try this guide
forum.ih8mud.com/79-95-toyota-truck-tech...ing-hub-rebuild.html
The second and third pictures show the part that wears, as the car is driven in freeewheel the inside is still and wears a thin bronze bush in the outside plate.
I'm a little worried that the CV joint is not retained in these hubs (an SJ has a circlip), it stays in place because when you turn the wheel, the joint pivots and pushes itself out. I'd be inclined to make a top hat bush with a hole in and attach to the threaded hole in the end of the CV joint to keep the joint pulled out.
- apfriend
vitara_mad wrote: have you found out what the problem with the speedo ???
I will bear this in mind!! Thanks lol
Will be looking at wiring/plug first...will be a weekend thing too busy this week to get to the garage
- apfriend
They say they are in working order.......but I want to strip them and recondition them at work anyway, so...
Do I need any particular spare parts? Anything that wears normally?
Or can I literally strip clean and rebuild them?
