Speedo stuck on 50mph & No 4x4 light /drive
- apfriend
- Visitor
27 May 2012 19:58 #41252
by apfriend
Speedo stuck on 50mph & No 4x4 light /drive was created by apfriend
Hi Everyone!
I'm new so be nice
Bought my first Jimny, its a 2001 model & been lifted 3" and has pro comp es3000 shocks and 235x75 tyres already fitted by last owner.
Anyway, the Jimny seemed to go into all the gears fine (didn't know about the 4x4 light at this time) and on the way home the speedo was fine. but when we stopped & set off again the speedo went a bit mad and stopped on 50mph?
Also we found that 4x4 was not engaging either (muddy field test)
There is a plug on the transfer? case and it is taped up with a lot of electrical tape.....is this the speedo drive / sensor for 4x4?
Where do I start ?
Thanks,
Andy
I'm new so be nice
Where do I start ?
Thanks,
Andy
- markyp2000
- Visitor
27 May 2012 20:34 #41255
by markyp2000
Replied by markyp2000 on topic Re: Speedo stuck on 50mph & No 4x4 light /drive
there are to sensors on the transfer box speedo and 4 wheel drive but a common fault for the 4x4 not working is the small pipes on the front axle thay run down the drivers side front trailing arm there a few on there check them for splits but you may as well replace all of them for peace of mind as for the speedo i dont no but id take the tape off and have a look
- Sam_
- Visitor
27 May 2012 20:43 #41256
by Sam_
Replied by Sam_ on topic Re: Speedo stuck on 50mph & No 4x4 light /drive
The other thing you could do if your 4 wheel drive is not engaging is put manual locking front hubs on it so you know you've selected 4x4 as you did it manually! Apparently the vacuum hubs not working properly is quite a common fault.
- apfriend
- Visitor
27 May 2012 20:51 #41257
by apfriend
Replied by apfriend on topic Re: Speedo stuck on 50mph & No 4x4 light /drive
I thought when the 4x4 wasnt working then you get a "flashing 4x4 light". I have no light at all?
I did read about locking hubs and using ones off of a vitara or SJ? And using the adapter plates available in the BIGJIMNY shop.....?
Is it as easy as bolt on and off.
As for the speedo, will have to examine the wires/plug further next weekend i guess
- markyp2000
- Visitor
27 May 2012 20:58 #41259
by markyp2000
i have no light ither but then i have manual lockers but you may find the bulb has been remoned cos there is a problem with it its just trial ans error on diagnoising it where are you in the uk
- Sam_
- Visitor
27 May 2012 21:01 #41260
by Sam_
Yeah, sorry must of missed the bit about no light at all, mine was flashing and the previous owner had locked the standard hubs, but as I use it everyday I wanted free wheeling hubs so I got some superwinch ones and using the big jimny kit bolted them straight on. (well after just opening up the holes slightly with a drill)
Not so sure what It means to have no light at all though sorry.
Time to create page: 0.133 seconds
