bleeding brakes
- Thank you received: 77
16 May 2012 17:47 #40433
by robs5230
standard jimny - for now
Replied by robs5230 on topic Re: bleeding brakes
facade , can you explain how to bleed the brakes using this valve ??
thanks rob
thanks rob
- 247sniper
16 May 2012 18:18 #40435
by 247sniper
Replied by 247sniper on topic Re: bleeding brakes
If your not confident or competent just keep it simple and bleed from each wheel.
Make it easy for yourself ! :blink:
Steve.
Steve.
16 May 2012 18:54 #40439
by robs5230
i dont mind easy jobs as long as i'm not shortcutting by not using the bleed valve. the car isn't a daily driver ( yet ) and i can devote plenty of time getting it right.
16 May 2012 22:33 - 16 May 2012 22:35 #40485
by facade
Same way as any wheel cylinder, just pretend that it has 3 front wheels.
Grandmothers and eggs maybe but
1 Fill reservior
2 Get someone in drivers seat with window open.
3 put ringspanner over nipple
4 attach hose.
5 stick hose into bottle.
6 Shout "down &hold"
7 Undo nipple.
8 Pinch up nipple
9 Shout "release"
Repeat from 6 until there are no bubbles
When the liquid in the bottle looks significant, top up the reservoir with new fluid.
TBH, most people don't bother with it, as they don't know it is there, not a disaster, as there is no reason for air to get into the line going back to the compensator if the compensator isn't removed.
So I suggest bleeding the front 2 first, then when you have a pedal, bleed the extra one (not the recommended practice: start with the one furthest away from the master cylinder) this will save introducing extra air into that long pipe run.
There shouldn't be any air in the back wheels either if you only messed with the front, but bleed anyway, only 1 nipple on passenger side BTW.
Replied by facade on topic Re: bleeding brakes
robs5230 wrote: facade , can you explain how to bleed the brakes using this valve ??
thanks rob
1 Fill reservior
4 attach hose.
7 Undo nipple.
8 Pinch up nipple
9 Shout "release"
Last edit: 16 May 2012 22:35 by facade.
17 May 2012 04:44 #40488
by robs5230
thanks very much , again, for all the advice guys.
rob
rob
- rogerzilla
03 Sep 2023 15:27 #250648
by rogerzilla
Replied by rogerzilla on topic bleeding brakes
Just to add to this info, ABS-equipped cars* just have the three nipples (FL, FR and RL). There is no LSPV.
*Clues: ABS warning light when you turn on the ignition, and an ABS pump unit in the nearside engine bay with brake pipes coming out of it.
Time to create page: 0.333 seconds
