bleeding brakes
16 May 2012 05:46 #40389 by robs5230
bleeding brakes was created by robs5230
there are a lpt of jobs i have never done on cars. this is another .
after a front caliper rebuild , is there a sequence to bleeding the brakes and do i have to bleed all 4 ?
thanks
standard jimny - for now
  • 247sniper
16 May 2012 06:29 #40393 by 247sniper
Replied by 247sniper on topic Re: bleeding brakes
Did you clamp of the brake flexy pipe on the side you were working on? If you did you only need to billed that brake, and the other side when you have done that Calipar.
If you have just let the fluid run though while you were working on the Calipar and run out then you will have to,bleed the whole system as the whole system will have air in it.
Did you clamp of the brake flexy pipe?
Steve.
16 May 2012 06:33 #40394 by robs5230
Replied by robs5230 on topic Re: bleeding brakes
no , i didn't clamp as it has goodridge steel braided hoses and didn't want to kink them so it look like i have to bleed all round :(
is there a sequence ??
thanks
  • vitara_mad
16 May 2012 07:25 #40397 by vitara_mad
Replied by vitara_mad on topic Re: bleeding brakes
you bleed brakes by starting from the furthest away from the master cylinder & work your way to the closest
  • 247sniper
16 May 2012 09:27 - 16 May 2012 09:28 #40403 by 247sniper
Doesn't make much difference really, some workshop manuals say start at the furthest point and some say start at the closest point. I always start at the closest, having bled thousands of brakes over the years as a vehicle tech, I have never had a problem. I'll be servicing my Jimny this week end and I'll be bleeding the brakes, I will be starting at the drivers front wheel. ;)
You wouldn't do any harm bleeding it either way mate.
Steve.
Last edit: 16 May 2012 09:28 by 247sniper.
16 May 2012 16:22 #40423 by facade
Replied by facade on topic Re: bleeding brakes
There is a bleed valve on the brake compensator above the rear axle that bleeds the front brakes. :huh:
