fitting a spring spacer to cure the jimny lean
- Johnniehec
- Thank you received: 56
15 May 2012 12:57 #40340
by Johnniehec
Here's a better picture
Replied by Johnniehec on topic Re: fitting a spring spacer to cure the jimny lean
Johnniehec wrote:
robs5230 wrote: hi i need to fit a spacer to cure the lean on the front drivers corner. what is the easiest way of doing this ?
is it jacking up the car and compressing the spring ?
cheers
Rob try it the other way round ie compress the spring then jack it up, you can bind the springs with two (on opposite sides) small ratchet straps then jack it up. Like this, obviously not a Jimny spring but you get the idea.
Cheers,
John.
- Thank you received: 77
15 May 2012 21:09 #40372
by robs5230
standard jimny - for now
Replied by robs5230 on topic Re: fitting a spring spacer to cure the jimny lean
now i understand , gonna order a yellow ratchet strap the missus is in for a treat
seriously this is what i was thinking of trying. cheers
Time to create page: 0.131 seconds
