fitting a spring spacer to cure the jimny lean
- Thank you received: 77
13 May 2012 07:39 #40108
by robs5230
standard jimny - for now
fitting a spring spacer to cure the jimny lean was created by robs5230
hi i need to fit a spacer to cure the lean on the front drivers corner. what is the easiest way of doing this ?
is it jacking up the car and compressing the spring ?
cheers
cheers
- darthloachie
- Visitor
13 May 2012 09:28 #40112
by darthloachie
Replied by darthloachie on topic Re: fitting a spring spacer to cure the jimny lean
yep
bits for vits sell a single spacer
13 May 2012 09:44 #40114
by robs5230
Replied by robs5230 on topic Re: fitting a spring spacer to cure the jimny lean
cheers yes i have ordered the spacer just looking for instructions on fitting it. if i use spring compressors can i keep everything attached ? shocks etc ?
- myers647
- Visitor
13 May 2012 18:40 #40152
by myers647
Replied by myers647 on topic Re: fitting a spring spacer to cure the jimny lean
Hi mate undo the shock,Jack the car up as high as possible and the axle will drop down, there should be enough room to put the spacer into place without using a spring clamp. I used a forklift truck when I put mine in and this worked.
Thanks
James
Thanks
James
13 May 2012 18:44 #40153
by robs5230
many thanks
- Johnniehec
- Thank you received: 56
15 May 2012 12:50 - 15 May 2012 12:53 #40337
by Johnniehec
Rob try it the other way round ie compress the spring then jack it up, you can bind the springs with two (on opposite sides) small ratchet straps then jack it up. Like this, obviously not a Jimny spring but you get the idea.
Cheers,
John.
Replied by Johnniehec on topic Re: fitting a spring spacer to cure the jimny lean
robs5230 wrote: hi i need to fit a spacer to cure the lean on the front drivers corner. what is the easiest way of doing this ?
cheers
Cheers,
John.
Last edit: 15 May 2012 12:53 by Johnniehec. Reason: Add pic
Time to create page: 0.143 seconds
