oil light flickering on
  • miksyellowsj
  • Visitor
  • Visitor
12 May 2012 14:08 #40061 by miksyellowsj
Replied by miksyellowsj on topic Re: oil light flickering on
yep oil level is fine its only dripping a little since kirton last weeknd found the switch and cleaned spade on it think im going to pull it out and fit my diesel instead of messing with it thanks guys
12 May 2012 16:50 #40076 by kirkynut
You could easily swap the switch over for a new one now you've found it. If it is that it's a cheap fix and quick so you don't have to do the diesel swap so soon if you've not planned for it yet.
Otherwise it's the pump or blocked oil galleries.
  • 247sniper
  • Visitor
  • Visitor
12 May 2012 20:42 #40099 by 247sniper
Replied by 247sniper on topic Re: oil light flickering on
Either the oil pump or the pressure relive valve it sounds like.
Steve.
  • miksyellowsj
  • Visitor
  • Visitor
13 May 2012 21:29 #40182 by miksyellowsj
247sniper wrote: Either the oil pump or the pressure relive valve it sounds like.
Steve.
where is the presure relive valve??
plans didnt go ahead this weeknd so its still got the engine in
  • 247sniper
  • Visitor
  • Visitor
13 May 2012 21:33 #40184 by 247sniper
It's part of the oil pump mate. You will have to remove the oil pump to inspect it.
You might be able to investigate further by removing the sump pan.
Steve.
13 May 2012 23:44 - 13 May 2012 23:46 #40204 by facade
Replied by facade on topic Re: oil light flickering on
Can you not just change the oil pressure switch for a new one like they keep saying?
I must have had half a dozen fail since I've been driving, the diaphragm or whatever leaks, and oil gets both sides of it, so the switch needs more pressure to operate, and sometimes oil weeps out along the spade connector or around the rim of the plastic part.
Some cars will cut out if the light comes on to protect the engine, don't know if a jimny will.
Last edit: 13 May 2012 23:46 by facade.
Time to create page: 0.144 seconds
