detroit trutrack rear diff locker
- myers647
10 May 2012 10:07 #39815
by myers647
detroit trutrack rear diff locker was created by myers647
Hi just bought another Jimny with various mods including a rear detroit trutrack rear diff locker. Is there anything to look out for or listen for when I go pick it up to check it all works as it should as I'v never been in a truck with a diff locker.
Thanks
James
Thanks
James
- reaper
10 May 2012 11:39 #39823
by reaper
Replied by reaper on topic Re: detroit trutrack rear diff locker
listen for it clunking as it self releases , just be careful on corners as they can wind up and lock
- myers647
10 May 2012 12:04 #39826
by myers647
Replied by myers647 on topic Re: detroit trutrack rear diff locker
ha that dosn't sound very good mate. So in a straight light in shouldn't feel any different or sound different from a diff without the locker? has your mate got back to you ref your PM?
- darthloachie
10 May 2012 12:14 #39827
by darthloachie
Replied by darthloachie on topic Re: detroit trutrack rear diff locker
the locker is fine on road, on normal bends you won't notice it, for tighter turns (road junctions etc) just try to turn under gentle power rather on a trailing throttle as it will ensure the diff unlocks
the worst you notice is a bit of gentle understeer in the wet
with a lifted truck you won't be going that fast anyway
- bluejimny
10 May 2012 12:57 #39835
by bluejimny
100% as above!
Replied by bluejimny on topic Re: detroit trutrack rear diff locker
darthloachie wrote: the locker is fine on road, on normal bends you won't notice it, for tighter turns (road junctions etc) just try to turn under gentle power rather on a trailing throttle as it will ensure the diff unlocks
100% as above!
Time to create page: 0.162 seconds
