Vacuum lines
  • tring
09 May 2012 20:17 #39772 by tring
Vacuum lines was created by tring
Hi
Anyone done or have pointers to front axle vacuum pipes FWD renewal to nylon or copper
All pipes below engine level are pastry and one side broken off.
Was wondering how the pipes were inserted/held in the rayon/rubber hub pipes
Parts cat - wheel hub piping
Ref No - 33 -- HOSE, SPINDLE VACUUM 4WD 43926-81A20
Would replace all piping from ref 8/9 down to hubs
Any pointers would be appreciated
Thanks
Jimny 2001
Catalog SN413V-2
Model Jimny
Eng no M13A-1072667
R SN Model Series
SC Eng & Trans SN413V, 4WD, MT
C JLX w/AirBag Grade
B Type 2 model
  • dirtydogz
09 May 2012 20:30 #39776 by dirtydogz
Replied by dirtydogz on topic Re: Vacuum lines
have a look at this topic on replacing vac pipe.
www.bigjimny.com/index.php/forum/7-jimny...s-with-silicone-hose
Hope this helps.
DIRTYDOGZ
  • tring
10 May 2012 11:26 #39821 by tring
Replied by tring on topic Re: Vacuum lines
Thanks for the thread.
Seems to be helpful views and completions
Silicon and copper seem to have be the completed ones and congrats to them (found silicon on e-bay easily enough but small bore tee's and elbows seem to be missing, start at 25mm for a 4mm hose.)
My hard nylon co2 fittings on mig have quick straight and 90 couples, but again i have not seen tee's, I'll look into them both again for fittings my local landlady got me the bottles and piping for the mig so i will start there to find fittings.
appreciated
  • tring
10 May 2012 12:36 #39830 by tring
Just found
(not sure about link rules)
xxxx://www.festo.com/pnf/en-gb_gb/products/catalog xxxx
is a co.uk as well.
Who put me on to a local supplier and the guy was very helpful saying that the products are used in auto , pharamacutical, space (:-\ and many other industries for both pneumatic and vacuum applications.
Means I can get some stools setup and make a start after house build finishes(my son)
Maybe someone can get some use out of the link and get a supplier closer to them..
Anyway it was the other thread that pushed me down the road so thanks again
  • rooster
10 May 2012 19:22 #39877 by rooster
Replied by rooster on topic Re: Vacuum lines
hi guys. had the same problem just before a muddy trip out so popped into halfords and managed to pick up some vaccum pipe and a selection box of plastic pipe inserts , straight and 't' pieces. all fitted and never had a problem since. :) :) :) hope this may be some use
Time to create page: 0.162 seconds
