1.9 diesel conversion will it fit???
  • miksyellowsj
08 May 2012 21:12 #39654 by miksyellowsj
1.9 diesel conversion will it fit??? was created by miksyellowsj
i have the chance at a 1.9 diesel on a ldv box and all the bits will this fit in the engine bay off a jimny?
thanks mik
  • Rockwatt
08 May 2012 21:33 #39659 by Rockwatt
Replied by Rockwatt on topic Re: 1.9 diesel conversion will it fit???
Yep Suzuki managed to do it for other countrys with the xud motor
  • miksyellowsj
08 May 2012 21:45 #39663 by miksyellowsj
Replied by miksyellowsj on topic Re: 1.9 diesel conversion will it fit???
ill not have any problems with the sump or anything like that what do you think ill have to alter or make to make it fit?
  • Rockwatt
08 May 2012 21:51 #39664 by Rockwatt
I'll see my dealer friend see if I can find out what's specific to the Jimny fit but I suspect it will be sump, manifolds, especially if it's a turbo, bell housing and clutch.
  • miksyellowsj
08 May 2012 21:57 #39665 by miksyellowsj
i suppose the tunnel will need cutting a little to i also have a 1.5 corsa diesel engine already mounted to a sj box, it was sat in my sj on the same mounts and gearbox mounts do you think that will be a better option? and a better fit?
  • Rockwatt
08 May 2012 22:33 #39668 by Rockwatt
Probably but a Bit under powered. Maybe use that setup with a gm/isuzu 1.7
Time to create page: 0.168 seconds
