Help! suspected misfire.
07 May 2012 15:49 - 07 May 2012 15:49 #39504
by dirtydogz
2002 JLX Soft Top
Replied by dirtydogz on topic Re: Help! suspected misfire.
YES
2002 JLX Soft Top
Last edit: 07 May 2012 15:49 by dirtydogz.
- myers647
- Visitor
07 May 2012 18:06 #39516
by myers647
Replied by myers647 on topic Re: Help! suspected misfire.
Yes mate there under the cover.Mine had broken If i touched the cable I got a shock off it :blink: :blink:
- Mala43B
- Visitor
08 May 2012 20:52 #39646
by Mala43B
Replied by Mala43B on topic Re: Help! suspected misfire.
Checked my plugs and leads and no obvious faults plus a mate had a OBD2 diagnostic tool and scanned for fault codes, however there were non logged so I'm puzzled as to why I had the fault.
A pal said it may hav been crap in the fuel that may of temporarily blocked the injector and then cleared.
Any ideas?
Any ideas?
08 May 2012 23:10 #39691
by facade
Replied by facade on topic Re: Help! suspected misfire.
Crank sensor between the alternator and the engine block.
Often doesn't give a fault code.
Wait until it happens again, then cool the sensor by pouring cold water on it, if it fixes the fault, change the sensor.
- X-Eng Simon
- Visitor
08 May 2012 23:36 - 08 May 2012 23:37 #39695
by X-Eng Simon
Replied by X-Eng Simon on topic Re: Help! suspected misfire.
Crank or cam position sensors! They often start to malfunction as they get hot - as they likely would at 70mph. As has been said, the ECU does not always register them as a fault.
Try heating up each of them with a hair dryer with the engine idling. If it replicates the misfire - there's your problem.
Si
Si
Last edit: 08 May 2012 23:37 by X-Eng Simon.
- Mala43B
- Visitor
10 May 2012 21:02 #39908
by Mala43B
Cool tip, I'll have to try that one, thanks.
Si
