Help! suspected misfire.
- Mala43B
- Visitor
07 May 2012 11:00 #39465
by Mala43B
Help! suspected misfire. was created by Mala43B
Hi when traveling home from a night out camping my Jimny suddenly started to misfire (or at least I think it was) at about 70mph. There was no engine warning light and the temp was reading Ok but the rev counter was jumping wildly with the whole car seemed to shudder.
This is the first time it has done this and it only lasted for a few minutes then it all seemed ok. It started after about an hour of driving on country roads.
My Jimny is a 2001 X REG with the M13A engine has only 70000 miles on it and is Japanese built.
- Sandez
- Visitor
07 May 2012 12:49 #39472
by Sandez
Replied by Sandez on topic Re: Help! suspected misfire.
I would have a guess that its the cam angle sensor (sensor at the front top of the engine). They are a common problem with the Jimnys
07 May 2012 14:06 #39482
by kirkynut
Replied by kirkynut on topic Re: Help! suspected misfire.
Ideally you could do with seeing if it's saved any fault codes despite the engine management light not being on.
Have a look at the scan guage Martin and I have got - Martin has done a bit on his on the website. Not all OBD2 scan tools seem to work on Jimny's for some reason.
But if it's not done it since, it might be worth just crossing your fingers and hoping for the best - if you have some break down cover that is!!!
- Mala43B
- Visitor
07 May 2012 14:30 #39486
by Mala43B
Replied by Mala43B on topic Re: Help! suspected misfire.
That's what I'll probably end up doing, as for break down cover, I aint got, YET...!kirkynut wrote: But if it's not done it since, it might be worth just crossing your fingers and hoping for the best - if you have some break down cover that is!!!
- myers647
- Visitor
07 May 2012 14:33 #39487
by myers647
Replied by myers647 on topic Re: Help! suspected misfire.
Hi mate try all the HT leads, one of mine broke and it started to judder when I put my foot down. It may have come a little loose or you may just need a new one.
Thanks
James
Thanks
James
- Mala43B
- Visitor
07 May 2012 15:30 #39499
by Mala43B
Time to create page: 0.156 seconds
