my uj help
  • suzuki jimny fella
04 May 2012 13:24 #39288 by suzuki jimny fella
my uj help was created by suzuki jimny fella
do any one no where to get uj cheap thanks
or can i steal them from my old middle prop :laugh:
just got a bit of movement up and down not when you turn it if that helps
can i just tap the caps in a bit for now
thanks again guys
  • dirtydogz
04 May 2012 17:53 #39300 by dirtydogz
Replied by dirtydogz on topic Re: my uj help
  • adamatdraycott
04 May 2012 20:05 #39308 by adamatdraycott
Replied by adamatdraycott on topic Re: my uj help
You can try to get the one with a grease nipple... but they are hard to find.
The blue print ones are fairly readily available... and retail at between £25 and £40 i got mine for £28
Pic taken from SilverJimny's website...
Hope you don't mind Greg B)
04 May 2012 20:31 #39311 by suzuki jimny fella
Replied by suzuki jimny fella on topic Re: my uj help
do you have to re balance the prop when you change uj guys and can i use my old middle prop uj for now :-D
  • darthloachie
04 May 2012 21:33 #39320 by darthloachie
Replied by darthloachie on topic Re: my uj help
we just went to our local GKN driveshafts and they replaced it and checked the balance for £40
05 May 2012 07:33 - 05 May 2012 07:34 #39339 by facade
Replied by facade on topic Re: my uj help
The joint you want is a Quinton Hazel QL219 or ql529 (with grease nipple) Blueprint ADK83901
size 25 x 63.8 mm
The grease nipple version is fitted to
Shogun/pajero/L200/L300 front shaft
I used to just drop them into GKN as well, but they closed the factory near here :(
Last edit: 05 May 2012 07:34 by facade.
Time to create page: 0.182 seconds
