broken rear shock bolt - done
01 May 2012 18:50 - 06 May 2012 13:37 #39090 by robs5230
the chap i am buying my jimny from has just phoned to say it has a broken rear shock bolt that he found on checking it over before i collect. it is a lower bolt.
how big an issue is this and whats the way to go about sorting it. the car isnt far away and i can get it home without issues , just need to know how to sort it.
any help appreciated thanks , rob
standard jimny - for now
Last edit: 06 May 2012 13:37 by robs5230. Reason: completed
  • supergaz
01 May 2012 18:57 #39091 by supergaz
Replied by supergaz on topic Re: broken rear shock bolt - help please
Best thing to do is to grind the bolt flush, centre punch the centre, drill all the way through with a good quality drill bit, (NOT THE B&Q RUBBISH) Then use a long bolt all the way through with a nyloc nut. Do this both sides as if it is to shear in the future its a simple knock it out job to replace.
01 May 2012 18:59 - 01 May 2012 19:00 #39092 by mlines
Last edit: 01 May 2012 19:00 by mlines.
The following user(s) said Thank You: robs5230
01 May 2012 19:12 #39094 by robs5230
nice cheers guys. will the brackets in the jimny shop help when refitting ??
  • supergaz
01 May 2012 19:20 #39095 by supergaz
The brackets will take the stress out of the lower bush if you have a lift, they also add an extra 1.5" length to the shock.
  • reaper
01 May 2012 19:28 #39097 by reaper
Replied by reaper on topic Re: broken rear shock bolt - help please
they can be hard to drill , if you can weld weld a nut or bar onto what is left and just unscrew it .
i would recommend then drilling out and bolting right through
Time to create page: 0.089 seconds
