crank angle sensor
  • daggs5
24 Apr 2012 08:03 #38469 by daggs5
crank angle sensor was created by daggs5
The crank angle sensor for the 13A jimny model is it located behind the starter motor and how do you get to it.
Thanks
Daggs5
24 Apr 2012 12:52 - 24 Apr 2012 12:53 #38483 by Obarno
Replied by Obarno on topic Re: crank angle sensor
The sensor is located behind the alternator. It doesn't take long to change. First remove the sliding adjusting bracket that holds the alternator away from the engine and is used to adjust the tightness of the belt, then loosen the bottom alternator bolt, it is a cap screw, from the radiator side. It only needs loosening, not removing, then fold the alternator towards the engine, remove the belt and fold the alternator away from the engine. The sensor is then clearly visible. Remove the connector, undo the 10mm head bolt and pull the sensor out. Replace the sensor and connector, tighten the bolt, and then refit fan belt and tighten everything back up again. Job done!
Last edit: 24 Apr 2012 12:53 by Obarno.
24 Apr 2012 16:27 #38493 by facade
Replied by facade on topic Re: crank angle sensor
Be very careful undoing that cap head bolt.
The head is made of a sort of compressed plasticine, and the hexagon hole will turn into a round hole quicker than you can swear :evil:
Make certain your hex hey is hammered right to the bottom of the hexagonal hole.
If it wont come undone, it takes half a day to dismantle the car, the radiator has to come out then the engine mount, then you can carefully undo the bolts holding the bracket to the engine and remove the whole alternator just to undo one bolt: the end you can actually get a socket to is actually a weld nut (Guess how I know this :angry: )
Time to create page: 0.149 seconds
