need help with a problem
  • FIRSTJIMNY
19 Apr 2012 13:15 #38000 by FIRSTJIMNY
need help with a problem was created by FIRSTJIMNY
Actually a couple of problems.
First, the little spring/s in my right rear wheel keep breaking. When they do it releases the brake pads and stops the Jimny dead in its tracks.
Is there some known reason this continues to happen?
2nd and please forgive me as I don't know the correct names of everything. Can the driveshaft yoke wear to the point that it can slip inside itself?
Thanks for your help.
  • wanderinstar
19 Apr 2012 14:10 #38003 by wanderinstar
Replied by wanderinstar on topic Re: need help with a problem
I am presuming you haes and drums on the rear, not pads. Do you have the springs in the correct position?
You don't say which driveshaft you mean. There are 4 drive-shafts and 3 propeller shafts.
  • adamjimny
19 Apr 2012 14:11 #38004 by adamjimny
Replied by adamjimny on topic Re: need help with a problem
Are they cheap springs?
And propshafts i think you mean.....never heard of one slipping
sent from my Samsung Galaxy S2 using Tapatalk
  • vitara_mad
19 Apr 2012 15:29 #38011 by vitara_mad
Replied by vitara_mad on topic Re: need help with a problem
no idea why your springs in the rear shoes are breaking never heard of that problem maybe there not fitted right
i presume you meen the prop shaft & yes they can wear & slip so if yours is simply get a replacement & bolt it on 5 min job
Time to create page: 0.157 seconds
