Big help needed
  • Top Rope Terry
14 Jul 2010 17:08 #3799 by Top Rope Terry
Big help needed was created by Top Rope Terry
hey guys hears one for ya i have a serious death wobble that seems to have got worse with little change to vehichle when i get it its at any speed and hitting a pot hole starts it off ,it sends me all over shakeing to the point where i have to slam on the brakes which makes it worse but stops the car and saves my arse. Any advice just to clean up the wobble a bit cause i'm just getting stressed. lol cheers
ps thank you to martin for the quick post on wheel bearing and snorkle good to know theres suppliers that care. B)
  • Jamie
14 Jul 2010 17:16 #3800 by Jamie
Replied by Jamie on topic Re:Big help needed
Sounds like you need to check your wheel bearings and maybe
shim up the kingpins!!!! Martin will probably tell you more!!
14 Jul 2010 21:06 #3808 by kirkynut
Replied by kirkynut on topic Re:Big help needed
There's another thread on the go similar to this at the minute and much has been written about this problem on here.
It appears that it may or may not be bearing related, if it is it's likely to be Kingpin bearings - not too harder job, did one on mine this afternoon.
I would also look at your track rod ends and front radius arm bushes.
Make sure there's no play in the steering box and adjust it if there is and basicaly ensure everyting is tickerdy boo on the front end!
Get any bearings from Martin as he is the cheapest I have found.
  • kevant
15 Jul 2010 22:18 #3845 by kevant
Replied by kevant on topic Re:Big help needed
Bang a steering damper on it so you can drive it around with some form of dignity while you sort out whats causing it i had exectly the same problem and the damper helped a lot plus its one of the cheaper mods if you use a defender damper.
16 Jul 2010 17:30 - 16 Jul 2010 17:32 #3854 by MigCooper
Replied by MigCooper on topic Re:Big help needed
Hi
I add the same problem, the front panhard was losse, i found also that a damaged bush could couse the same efects
Have a look at the srews first and also see if the panhard is well fixed in place
MigCooper
Snorkel and plenty of rust to be treated :)
Last edit: 16 Jul 2010 17:32 by MigCooper.
  • Top Rope Terry
17 Jul 2010 17:29 #3863 by Top Rope Terry
Replied by Top Rope Terry on topic Re:Big help needed
Thanks to everyone for the help i'll hope to fix it soon but what a pain in the arse it is when u can't use it for fear of tipping. B)
Time to create page: 0.154 seconds
