IDEA TO PREVENT BEARING FAILURES COMMENTS PLEASE
12 Apr 2012 10:51 #37405 by mlines
No eBay APP ID and/or Cert ID defined in Kunena configurationWhy not fit Landrover Gaiters, I dont know about the rubber ones but the older leather ones can be made to fit.
  • X-Eng Simon
  • Visitor
  • Visitor
12 Apr 2012 11:44 #37408 by X-Eng Simon
Pressure from the crank case (rocker cover) might be sufficient?
I've made my own gaiters for all kinds of things like this out of leather, 'stitched' with small cable ties. I bought a sheet of soft leather on eBay which is easy to cut and has made a dozen or so gaiters of one sort or another. If you rub grease into the surface before fitting, it waterproofs it. Then fill the interior with grease to lubricate the joint. It's actually the grease providing the waterproofing and the gaiter to stop the grease escaping.
Si
  • oxford_bloke
  • Visitor
  • Visitor
14 Apr 2012 20:32 #37594 by oxford_bloke
Replied by oxford_bloke on topic Re: IDEA TO PREVENT BEARING FAILURES COMMENTS PLEASE
just a thought could you not do something with the vacum pump. as there must be an exhaust of some kind on it
  • suzuki jimny fella
  • Visitor
  • Visitor
20 Apr 2012 17:58 #38136 by suzuki jimny fella
Replied by suzuki jimny fella on topic Re: IDEA TO PREVENT BEARING FAILURES COMMENTS PLEASE
hi my swiwl seal is starting to leak agen can i just buy the rubber seal and cv seal or do i have to buy the swiwl seal kit
or can i make my own swiwl seal lol lol
20 Apr 2012 19:19 #38159 by kirkynut
It's your axle oil seal that's leaking so you need to strip it and replace that along with whatever else is worn and allowing enough play in the shaft to make it leak - kingpin or wheel bearings.
  • Visitor
  • Visitor
20 Apr 2012 19:43 #38165 by suzuki jimny fella
thought it was
when i frist got my jimny the king pins had gone and was leaking all over the road but when i got new king pins and bearings and swiwl seal from j&j motors thay didnt give that axle seal that was one year ago and now its strating to leak agen
thay done me for £160 for that lot and no little axle seal :angry:
would my swiwl seal be ok though guys and just do the little axle seal
any one cleaned and painted the swiwl ball for a better seal lol lol
