IDEA TO PREVENT BEARING FAILURES COMMENTS PLEASE
- RED JIMNY
- Visitor
10 Apr 2012 20:22 #37232
by RED JIMNY
IDEA TO PREVENT BEARING FAILURES COMMENTS PLEASE was created by RED JIMNY
I’m sick of changing King pin & wheel bearings in my Jimny.
The other day I had an idea. The bearings general fail as a result of ingress of water / mud into the axle housing probably through the swivel seal.
Since I have long changed to manual hubs, my idea was to introduce a positive pressure down the 4 redundant pipes for the vacuum hubs thus preventing the water getting in.
At first I thought about tapping into the exhaust manifold but I’ve since gone off this idea due to corrosive nature of exhaust fumes.
So I’m currently thinking about a small pump such as windscreen washer pump or if this is not man enough a small compressor. This could be operated by a switch on the dash before entering water. Due to time constraints I probably never get around to trying this but what do you guys think?
- Bish
- Visitor
10 Apr 2012 21:15 #37244
by Bish
Replied by Bish on topic Re: IDEA TO PREVENT BEARING FAILURES COMMENTS PLEASE
The theory is sound. why not give it a go it can't do any harm.
11 Apr 2012 11:29 #37276
by kirkynut
Replied by kirkynut on topic Re: IDEA TO PREVENT BEARING FAILURES COMMENTS PLEASE
I read an article in Total Off road about a chap with a Series LR who did not want to lose his drum brakes for some stupid reason but built it into a challenge truck, so was going through muddy water alot. He drilled his drum back plates and screwed fittings in for compressed air connected to a compressor and turned it on when wading.
It worked well apparently.
So it's worth a try and is something I've considered since reading that article, however, I am not happy with the other effects of muddy water on my Jimjam and would like it to last the test of time, so I've just stopped driving through crap!
Sent from my HTC, using my fingers!
- adamjimny
- Visitor
11 Apr 2012 14:23 #37291
by adamjimny
Replied by adamjimny on topic Re: IDEA TO PREVENT BEARING FAILURES COMMENTS PLEASE
I may have a look at work for the bits needed because iv googled it all including positive pressures etc and seems to work well
sent from my Samsung Galaxy S2 using Tapatalk
- teafortwo0789
- Visitor
11 Apr 2012 21:47 #37357
by teafortwo0789
Replied by teafortwo0789 on topic Re: IDEA TO PREVENT BEARING FAILURES COMMENTS PLEASE
Sounds a fair idea. I've been wondering if it might be possible to use rubber TWO swivel seals under the metal ring per side! Crazy or might it be practicle??
- wanderinstar
- Visitor
12 Apr 2012 09:01 #37396
by wanderinstar
Replied by wanderinstar on topic Re: IDEA TO PREVENT BEARING FAILURES COMMENTS PLEASE
I think you and I are working to the same goal. We ought to put our heads together,.
