tyre size
- suzuki jimny fella
08 Apr 2012 20:05 #37087
by suzuki jimny fella
tyre size was created by suzuki jimny fella
hi all can you help i have got 5.5j sj rims what is the max tyre size that i can put on them i have got 215 80 15 on now can i get 30/31inch on them
- Paul4x4
09 Apr 2012 16:01 #37143
by Paul4x4
Replied by Paul4x4 on topic Re: tyre size
Yes, you can put 31/10.5 on them, but I wouldn't go with any wider than that.
09 Apr 2012 16:36 #37149
Replied by suzuki jimny fella on topic Re: tyre size
are you sure fella any one else done this with these sj rims 5.5j and can you ture them around because thay are tapered for the nuts on the back side of the rim
- Paul4x4
09 Apr 2012 17:40 - 09 Apr 2012 17:45 #37153
by Paul4x4
Many people have fitted 31" on their SJ's using stock wheels. Including me a long time ago, so I know that's possible. So sure it can be done on Jimny's too.
And what comes to turning the wheels, it can be done too, but you should drill new holes for valves, and weld up the old one's.
EDIT: If you turn them, make sure that they fit on the rear drums before drilling and welding, because I'm not sure how much bigger Jimny rear drums are compared to SJ410. Turned wheels can't be installed on SJ413 because of bigger drums, but on SJ410 they will fit nicely.
Last edit: 09 Apr 2012 17:45 by Paul4x4.
09 Apr 2012 18:00 #37155
ok mate will get pics up thanks
5.5j stock 31.10.50.15 will fit then
- zukenutter
10 Apr 2012 10:34 #37191
by zukenutter
Replied by zukenutter on topic Re: tyre size
I wouldn't put anything bigger than 29x9.
235s go really nice on 5.5 rims
Time to create page: 0.170 seconds
