more steer one way and noise from wheel
- garrygun
- Visitor
06 Apr 2012 19:00 #37005
by garrygun
more steer one way and noise from wheel was created by garrygun
Hi guys,drove my jimny today, started to make noise from rh side wheel then had restricted steering one way then it changed to the other lock.
Also the clutch is ever so heavy.
Any helpful info would be appreciated
Its 2002 model jlx
Its 2002 model jlx
- supergaz
- Visitor
06 Apr 2012 19:03 #37008
by supergaz
Replied by supergaz on topic Re: more steer one way and noise from wheel
Sounds like maybe wheel bearing, and swivel (king pin) bearings will be shot.
Jack the front wheel up and give it a shake top to bottom.
- darthloachie
- Visitor
07 Apr 2012 10:58 #37034
by darthloachie
Replied by darthloachie on topic Re: more steer one way and noise from wheel
think its a cv joint
- Smoggy
- Visitor
07 Apr 2012 13:39 #37038
by Smoggy
Replied by Smoggy on topic Re: more steer one way and noise from wheel
Have a quick check of your master cylinder fluid level, i had similar symptoms and found my reservoir was nearly empty due to leak.
- garrygun
- Visitor
07 Apr 2012 14:18 - 07 Apr 2012 14:19 #37040
by garrygun
Replied by garrygun on topic Re: more steer one way and noise from wheel
think you are right, not had chance to inspect yet as its locked up at work.
i will check the resevour just in case.
Last edit: 07 Apr 2012 14:19 by garrygun.
07 Apr 2012 16:18 #37049
by kirkynut
Replied by kirkynut on topic Re: more steer one way and noise from wheel
You are not driving it in 4wd on the road are you ... just checking as I notice you are quite new and might not realise that this is a sin!
Time to create page: 0.156 seconds
