need some help finding the right brake disc to purchase
  • richie60
  • Visitor
  • Visitor
15 Apr 2012 14:25 #37629 by richie60
great tip. will have a closer look at that. if it was a seized caliper, would that not affect braking performance in any way? Mine feels ok when braking, ie slows down without too much foot pressure, also, the vehicle has only seen road use so probably would not accumulate too much crud around the pads, but i will have a good look anyway...
richie
15 Apr 2012 18:35 #37658 by facade
What actually seizes are the sliding pins, with rubber boots on each end. Clean them up and grease with rubber grease NOT copaslip. Copaslip makes the rubber boots swell up and seizes the slide pins....
  • adamatdraycott
  • Visitor
  • Visitor
16 Apr 2012 14:33 #37740 by adamatdraycott
I must be very very light on brakes... i'm on the factory fitted discs after 52,000 miles and only chnaged the pads from the factory fitted ones about 3k ago!
I do tend to drop down through the box rather than standing on the anchors though
Time to create page: 0.128 seconds
