need some help finding the right brake disc to purchase
- richie60
- Visitor
04 Apr 2012 13:38 #36920
by richie60
need some help finding the right brake disc to purchase was created by richie60
Sorry to sound a bit thick on this one, but i'm confused as to the correct brake disc to buy for my 08 Jimny.
Done some searching on the web and it appears there are 2 different sizes based on the hub hole centre, one being 107mm (the cheaper one) & the other is 108.3mm.
As far as I know, my vehicle is 16V DOHC and the VIN NO. is 00352222.
I have a feeling that i'm going to need the expensive discs! Can anyone advise?
Richie
Richie
04 Apr 2012 15:07 #36924
by Obarno
Replied by Obarno on topic Re: need some help finding the right brake disc to purchase
For your car you will need the one with the bigger hole.
- adamatdraycott
- Visitor
05 Apr 2012 09:23 #36962
by adamatdraycott
Replied by adamatdraycott on topic Re: need some help finding the right brake disc to purchase
I'd be worried about needing a set of discs on an 08 plate
What is wrong with the old ones?
- richie60
- Visitor
05 Apr 2012 12:30 #36965
by richie60
Replied by richie60 on topic Re: need some help finding the right brake disc to purchase
They're warped! Only 27000 on the clock, but you can feel the shakes when you brake, also when braking under slow speed, you can feel it through the brake pedal.
The OEM parts must be cheap metal!
- Juggernaut
- Visitor
14 Apr 2012 16:09 #37569
by Juggernaut
Replied by Juggernaut on topic Re: need some help finding the right brake disc to purchase
I'd take the front brakes apart and clean them. Mine was pulling right and shaking the wheel pretty bad, of course I thought discs. But when I tore them apart to install the new ones I saw that the left caliper wasnt closing all the way due to crud. I usually try to look and fix before I order parts, but I got lazy and now I have new discs I didn't need.
14 Apr 2012 18:44 #37579
by facade
Replied by facade on topic Re: need some help finding the right brake disc to purchase
Check that there isn't a seized calliper when you fit new discs.
Modern pad material wrecks discs if you use the brakes: 15-20,000 from a pair of discs is normal around town, especially if the car stands idle some of the time.
Time to create page: 0.160 seconds
