Rear brakes now bigger problem
- ronm
26 Jun 2010 13:11 - 27 Jun 2010 19:45 #3679
by ronm
Rear brakes now bigger problem was created by ronm
Driving around yesterday a mystery metallic clicking started from rear offside wheel.Thought the usual sort of thing, maybe picked up a stone in the tread or poss a nail. Stopped and inspected tyre and found nothing.
Today removed wheeel for closer inspection and nothig,removed drum no probs all clean and nothing broken.
Put wheel back on without drum and rotated to see if wheel bearing all well no probs.Put drum back and went for drive around the block and the clicking returned
Handbrake adjustment fine all brakes function fine.
Anyone any thoughts?
Last edit: 27 Jun 2010 19:45 by ronm.
26 Jun 2010 18:04 #3682
by kirkynut
Replied by kirkynut on topic Re:Rear brakes
I think this is one of htose things you need to be there to hear really.
Can you hear or feel it if you turn the drum with the wheel off?
Have you done some work on the car or has it just started without any changes to anything?
26 Jun 2010 18:33 #3684
Replied by mlines on topic Re:Rear brakes
When mine did this it was the handbrake cable hitting a balance weight on the inside of the wheel rim
- ronm
26 Jun 2010 19:33 #3685
by ronm
Replied by ronm on topic Re:Rear brakes
Hi Guys
Thanks your replies/
Martin will check out tomorrow
Robert no new work undertaken slight rubbing of shoe in beginning but that went after cleanig drum.Sounds like nail in tyre but nothing when jacked up
ronm
ronm
- ronm
27 Jun 2010 19:43 #3687
by ronm
Replied by ronm on topic Re:Rear brakes now bigger problem
no chance to look at brakes during day. now discover i might have left locking nut remover on wheel when i went for test run yesterday. now cant get wheels off. any thoughts before i drill out each wheel stud.
ronm
ronm
28 Jun 2010 05:43 #3688
Replied by mlines on topic Re:Rear brakes now bigger problem
Before using drills etc, just find an old socket and tap it on with a hammer onto the locking nut. Worked fine for me.
Time to create page: 0.162 seconds
