Fitting Manual Hubs
- shooter1122
01 Apr 2012 08:11 #36685
by shooter1122
Fitting Manual Hubs was created by shooter1122
Just fitting, or trying to fit, manual SJ hubs to my Jimny.
Following the comprehensive instructions all went well and have one side on. But then thought about seeing if they work so jacked the car up and put them into lock. I was hoping that the wheel would be unable to move in the lock position but unfortunately it just free wheeled. Is this right or am I missing something.?
Any suggestions gratefully received.
- doncarlyon
01 Apr 2012 08:12 #36686
by doncarlyon
Replied by doncarlyon on topic Re: Fitting Manual Hubs
Have you got it in 4wd?
- shooter1122
01 Apr 2012 08:14 - 01 Apr 2012 08:26 #36687
by shooter1122
Replied by shooter1122 on topic Re: Fitting Manual Hubs
Yes I did
I do also get a clunk when in locked position and turning the wheel
Last edit: 01 Apr 2012 08:26 by shooter1122.
- shooter1122
01 Apr 2012 10:09 #36695
by shooter1122
In addition, I have just found what appears to be a metal circlip in the box of the manual hubs. Is this the reason they don't work. If so, where does it go as i have no instructions for it.
01 Apr 2012 10:51 #36697
by facade
Replied by facade on topic Re: Fitting Manual Hubs
On the SJ you dismantle the freewheel unit, and bolt the back piece on the car. The CV splines stick through, and that circlip goes into a groove on the outside of the splines to stop them pushing back in.
On a jimny, you fit a spacer, and the circlip is already fitted on top of the thick washer inside the rim of the hub nut. This means the hubs are so far out that only 1/2 the splines engage, but no-one bothers as there is no problem.
If they are aisin hubs they only turn to lock with the top on correctly.
As to your problem, you need both hubs fitted and locked as well as 4wd engaged to test them.
- shooter1122
01 Apr 2012 11:59 - 01 Apr 2012 12:02 #36701
by shooter1122
Thank you for your advice.
All sorted.
Just a poor mechanic doing a simple job::
Do have a pair of vaccuum hubs to go on Ebay now though !
All sorted.
Last edit: 01 Apr 2012 12:02 by shooter1122.
Time to create page: 0.169 seconds
