Jimny LPG conversions
28 Mar 2012 06:15 - 28 Mar 2012 06:17 #36482
by kirkynut
Replied by kirkynut on topic Re: Jimny LPG conversions
You'll want multipoint on a Jimjam and it is the more expensive option.
I have a mate near to me in Essex who's business is fitting this and he is an offroader so knows what's needed off road too - ie:where tanks need to be fitted without getting damaged - his business is in a small village called Stambridge near to Rochford, Essex.
If it helps anyone I can find his number.
Last edit: 28 Mar 2012 06:17 by kirkynut.
- Sam_
28 Mar 2012 09:16 #36495
by Sam_
Replied by Sam_ on topic Re: Jimny LPG conversions
Yeah if you could find a number I'll be interested, I'll have another proper look next time I'm in the computer
- panosd
04 Apr 2012 16:35 #36932
by panosd
Replied by panosd on topic Re: Jimny LPG conversions
Better late than never. Here is the photo of the lpg tank of 60lt in my jimny.
Uploaded with ImageShack.us
04 Oct 2017 12:51 - 04 Oct 2017 12:53 #184828
by Bosanek
Replied by Bosanek on topic Jimny LPG conversions
I am also contemplating on installing an LPG fuel supply system in a petrol Jimny.
The first and main issue is the placement of the fuel tank. Jimny is already rather scarce on the cargo space.
While it is perfectly feasible to add a cylindrical LPG fuel tank in its trunk/boot, the tank will take at least 80% of the already tiny space in the trunk.
So the initiative is to figure out some alternative placement, in order to minimize the loss of space.
Placing the fuel tank under the vehicle is (in my opinion) not a viable option, as there is not much room underneath, and it would be exposed in all terrain driving conditions.
The only feasible underbody placement solution would be to remove the factory petrol fuel tank and install a different (much smaller) petrol fuel tank alongside a small LPG fuel tank. This is probably an expensive solution as it requires finding and incorporating a custom very small petrol fuel tank (and probably a hard to find very small LPG tank). Also, the vehicle would have a rather small range in both fuel types.
However, today a "combined" idea came to my mind - to use a little bit of trunk space and a little bit of underbody space!
Read on!
The trunk has a factory recessed space (a "ditch") which contains the factory tools like the jack, safety triangle, wheel nut wrench, etc.
The exhaust muffler is positioned below this recessed ditch, but there is a significant space between them (around 10 cm).
The idea is to completely cut out the recessed section from the trunk floor, and then weld in a much deeper recessed section there (so deep that it almost touches the exhaust muffler).
The new section should be made of stronger steel and with some additional braces to increase its load carrying capacity. Its bottom should be lined with some good heat insulating and heat resistant material, to isolate the heat from the exhaust muffler.
Then a small (but not too small) cylindrical LPG fuel tank should fit in this deep recessed space. About 1/2 to 2/3rd of the fuel tank would be in the hole, while the rest would take up the trunk space. However, the top of the LPG tank should be approximately level with the back of the rear seats when they are folded forward.
This means that a custom DIY metal or wooden box platform can then be constructed over the LPG tank, effectively providing a new boot floor on which to put the cargo. That new "floor" above the LPG tank would probably be level with the back of the rear seats when they are folded forward.
As for the placement of the jack, the triangle etc., they are easy to keep in a dedicated box or a bag in the trunk (and a hydraulic bottle jack and a semiprofessional long wheel nut wrench are better devices to have anyway!)
What do others think of this idea? Does it make sense?
Read on!
Last edit: 04 Oct 2017 12:53 by Bosanek. Reason: Typo
- Mraz
04 Oct 2017 19:24 #184848
by Mraz
Replied by Mraz on topic Jimny LPG conversions
If you're thinking about something like that.... why not relocate muffler or put smaller one and create more room for the LPG tank?
04 Oct 2017 19:49 - 04 Oct 2017 19:56 #184850
by Bosanek
Well those ideas are on the same line as mine - to locate the LPG tank half below the trunk and half in the trunk space (sort of).
Relocating the muffler or using a smaller one would further improve the options in this solution, but I do not know how expensive is that and what would the negative aspects of using a smaller muffler be.
In the meantime, I found a Polish company which produces a custom-made small petrol fuel tank + a holder for the LPG tank. This all fits in the space of the original 40 l petrol tank! The original fuel pump and the fuel gauge can be used in the small petrol tank.
Here it is:
rtech.com.pl/2016/10/31/zbiorniki-paliwa/
Here is the advertisement for that product on a Polish "ebay-alike" web shop:
allegro.pl/zbiornik-paliwa-kombo-suzuki-...ech-i6962219945.html
Here it is:
Last edit: 04 Oct 2017 19:56 by Bosanek. Reason: Link to a Polish web shop added
