4wd switch on dash
- suzuki jimny fella
20 Mar 2012 21:06 #36085
by suzuki jimny fella
4wd switch on dash was created by suzuki jimny fella
can this be done as when i am doing a few lanes in my area and 2wd high is to higher gear so was thinking of this so i can get 2wd low will this do any damage to my running gear
thanks
thanks
- VAXXi
20 Mar 2012 21:14 #36087
by VAXXi
Replied by VAXXi on topic Re: 4wd switch on dash
Had to re-read a few times your message :huh:
There is no 2WD-L. Are you asking if you can switch from 4WD-H to 4WD-L while driving ? if yes, the answer is no.
20 Mar 2012 21:46 #36089
Replied by suzuki jimny fella on topic Re: 4wd switch on dash
sorry can i put a switch on the dash to control the air locking hubs so when i nock it off i get 2wd low
- adamjimny
20 Mar 2012 22:31 #36094
by adamjimny
Much simpler idea that rich
Other wise could use a air valve in dash linked to the air line that operates hubs so you can block air flow or open it therefore controling the air hubs. (could even have electric switched valve so you can have a simple button on dash)
Sent from my GT-I9100 using Tapatalk
Replied by adamjimny on topic Re: Re: 4wd switch on dash
MysticRich wrote: Why not just fit freewheeling hubs ?
Time to create page: 0.149 seconds
