Summit Machine Extra Large Flex Joint
  • Monkey
12 Mar 2012 10:45 - 12 Mar 2012 10:46 #35347 by Monkey
www.lowrangeoffroad.com/index.php/summit...arge-flex-joint.html
Wonder how much longer these would last than the rubber bushes? I have done 24,000km's and all my rubber bushes are stuffed :( + these would reduce binding big time and maybe increase flex to :lol:
Does any one know the hole ID of the middle link of the rear radius arms? And same for the front to?
I think if the OD of these cool joint's are slightly larger than the jimny bushs holes in the arm's i could get them bored out and run these on the middle link of each arm and really soft rubber bushes on all the other links.
Thought's?
Last edit: 12 Mar 2012 10:46 by Monkey.
  • Paul4x4
12 Mar 2012 13:31 #35352 by Paul4x4
Replied by Paul4x4 on topic Re: Summit Machine Extra Large Flex Joint
My thoughts to anyone who wants REAL flex, and have some basic welding and fabricating skills, is to ditch the stock radius arms, and go for range rover front radius arms or similar. That's the only reasonable way to get the bushings last longer. And the chassis end of the arms won't restrict flex.
Stock Jimny arms are garbage in my opinion if you drive serious offroad...:whistle:
  • Sam_
12 Mar 2012 14:30 #35357 by Sam_
Paul4x4 wrote: My thoughts to anyone who wants REAL flex, and have some basic welding and fabricating skills, is to ditch the stock radius arms, and go for range rover front radius arms or similar. That's the only reasonable way to get the bushings last longer. And the chassis end of the arms won't restrict flex.
Lets see some pics!
  • Paul4x4
12 Mar 2012 15:34 #35362 by Paul4x4
Sam_ wrote: Lets see some pics!
I will show you some pics when I actually have something to show, lol!:laugh:
I'm currently only at the stage of gathering all the parts together, but you WILL see how my little blue Jimny turns into "monster" with yota axles, 33" tires and range rover radius arms...;)
  • Monkey
13 Mar 2012 12:18 #35431 by Monkey
Replied by Monkey on topic Re: Summit Machine Extra Large Flex Joint
Yota axles for 33's really? :unsure: There a few sierra's that run 36's on suzi diffs with out issues and one jimny on 34's, with out to much hassle and these guy's drive hard. I am against big heavy diffs for road driven zooks, because you have straight up lost the advantage of having a suzuki :whistle: (small diff's, light wight) but that's just me.
While rangie arm's are good, and won't have much (if any) binding, i would go to the extra effort of 3-link (2 lower's, one upper + panhard).
Also you say "basic welding and fabricating skills", this is a non-issue for me, as i'm a welder/fabricator by trade ;) but the issue is the a mod like i would want to run it pass a engineer as it would be a mod that can not be reversed easily if Mr Plod make's me go over the pit's for un-engineered mods which is that last thing i want, also not a cheap excise any more due to new rule's :(
The main reason for me wanting to run these joint's is to reduce wear and tear on all the rubber bushes, a bit of flex will be gained if i run these joint's , as to how much? - i don't really care - that's what locker's are for ;)
So can anyone actually answer my question about the holes sizes?
  • Paul4x4
13 Mar 2012 13:19 #35441 by Paul4x4
Monkey wrote: Yota axles for 33's really? :unsure: There a few sierra's that run 36's on suzi diffs with out issues and one jimny on 34's, with out to much hassle and these guy's drive hard. I am against big heavy diffs for road driven zooks, because you have straight up lost the advantage of having a suzuki :whistle: (small diff's, light wight) but that's just me.
Yeah, I want yota axles because of the reliability with full lockers over the stock axles, and I also like the added width. And, I can run 35" also with no problems if I want...:whistle:
And even though the 3-link rear is nice, I'm too lazy to do all the additional work as I already have a perfectly good chassis end mount for the panhard, lol!:laugh:
Don't know exactly what laws and rules you have in UK and Australia as I live in Finland, but it's legal here to swap in some better radius arms as long as they are from a heavier vehicle.
I need the strongest possible driveline and everything when I go to serious hardcore offroad mud safaris in Russia...B)
Sorry, won't mess with your thread anymore!:blush:
Time to create page: 0.173 seconds
