Bolts, Front Brakes.
- Asbojimny
31 May 2010 19:28 #3506
by Asbojimny
Bolts, Front Brakes. was created by Asbojimny
Help needed.
Does anyone know where we can get bolts that hold on the backing plate behind front discs. Theres 4 either side of truck and the heads on ours are well fecked. Even a part number. The trucks a 54 plate.
Cheers. Smiffy
Cheers. Smiffy
01 Jun 2010 04:14 #3508
Replied by mlines on topic Re:Bolts, Front Brakes.
Well the manual lists it as M10 x 25mm which are pretty easy to get hold of. Its doesn't state the thread which could be standard or metric fine.
If your feeling rich the part number is 09117-10057
Otherwise a quick search of the Internet will throw up lots of suppliers - I use www.shop4fasteners.co.uk/
- Thank you received: 115
01 Jun 2010 06:32 #3509
by maverick
Jalapeño, IISY?
Replied by maverick on topic Re:Bolts, Front Brakes.
maybe a fag-packet will suffice?
Jalapeño, IISY?
- Asbojimny
01 Jun 2010 14:44 #3512
by Asbojimny
Replied by Asbojimny on topic Re:Bolts, Front Brakes.
Cheers Martin,i'll "Obtain" some M10's from work and see if they fit.
Time to create page: 0.223 seconds
