Half Shaft and ABS Ring
- Thank you received: 115
31 May 2010 07:00 #3491
by maverick
Jalapeño, IISY?
Half Shaft and ABS Ring was created by maverick
As many of you know i had a falling over on my O/S last week (Henryd 26May2010) ... anyway i have sourced an O/S Half Shaft, but its from a non-ABS Jimny ... so therefore it dont have an ABS Ring on it, where as my broken Half Shaft does ...
Basic question is how do i get my ABS Ring off, without breaking it?
My thought is that the half shaft is STEEL, and the ABS Ring looks like Aluminium
Does Aluminium expand 'quicker' than Steel - so if i heat it with a blow torch just the ring, it should 'slide-off' huh?
(Lynne wont let me put the half shaft in the oven - :silly: )
Jalapeño, IISY?
31 May 2010 08:10 #3496
Replied by mlines on topic Re:Half Shaft and ABS Ring
I am sure Jamie on this website just applied heat (and the ABS ring is steel otherwise the sensor wouldn't work)
31 May 2010 08:20 #3497
by maverick
Jalapeño, IISY?
Replied by maverick on topic Re:Half Shaft and ABS Ring
Cheers Martin - of course its steel (doh) as that ABS Sensor is a magnet ... but really shiny-steel (is why i thought it was ally) ..
Jalapeño, IISY?
- Jamie
31 May 2010 16:01 #3501
by Jamie
Replied by Jamie on topic Re:Half Shaft and ABS Ring
Yes pal just get it cherry red and it pops off!!!
However, if you get a new bearing retainer from Suzuki, not as dear as
you would think, they come with them allready fitted!!!!
Oh yeah after you have heated the ring up to refit you will need
some bearing fit or you can pip the retainer!!!!
- foxshooter
31 May 2010 16:33 #3502
by foxshooter
Replied by foxshooter on topic Re:Half Shaft and ABS Ring
Its not the ABS ring that will be the problem, its the mounting for the ABS sensor.
It fits into a casting on the main part of the axle. Non ABS axles dont have this mount
I just had CAN suzuki send me the wrong axle type for a complete swap out. Thought about moving the ring but the mount for the sensor killed it off.
Axle being returned Tue for a swap out
Mark
Mark
31 May 2010 17:11 #3504
by maverick
Jalapeño, IISY?
I have a ABS Jimny with an ABS Sensor fitted - the half shaft i have is off a non-ABS Jimny ...
Jalapeño, IISY?
Time to create page: 0.187 seconds
