smoky startup
- bryandenham
18 May 2010 14:27 #3408
by bryandenham
smoky startup was created by bryandenham
Hi again,
2" spring spacers and damper extensions plus extended bump stops. seems ok so far.
Reason for writing is a cloud of smoke on stsrt up from cold, perfectly ok for rest of day. I did think valve stem oil seals but it doesn't smoke except on cold start. Any ideas folks? It has done 115,000 but goes well and starts fine with no smoke from rocker box with cap off or from breathers when dis-connected. Oil level is correct.
Is there a foible, (love that word), that just afflicts jimnies? Oh yes its the 16 valve single cam.
Thanks. Bryan D. Isle of Man.
- JonathonMarshall
20 May 2010 09:00 #3413
by JonathonMarshall
Replied by JonathonMarshall on topic Re:smoky startup
Well you've already checked what cured it for me. The oil was a little low and now its not done it since. Was definately oily type pale smoke on mine though.
- ml1275
21 May 2010 05:26 #3424
by ml1275
Replied by ml1275 on topic Re:smoky startup
Mine does this @ 60,000 miles (or so it says on the clock!) A proper smokers cough on cold startup.
ML
ML
- bryandenham
21 May 2010 16:23 #3434
by bryandenham
Replied by bryandenham on topic Re:smoky startup
thanks for the replies folks BUT who knows what the prob is OR can suggest anything??
Time to create page: 0.241 seconds
