Start up
  • Got Mud
17 May 2008 02:47 #34 by Got Mud
Start up was created by Got Mud
I just bought a Suzuki Jimny:laugh: with intentions to take this baby off road regular :woohoo: its still fully standard right now but i would like to buy some 15x31x10.5 Mudzillas rims and tires a 2inch body lift and 2 inch suspension lift
My question is is this to much for the Jimny's 1300cc engine?
If so what would be ideal tires sizes?
And or height for such a vehicle?
I have an entire family into car racing so there may be a GT Turbo Starlet engine actually 2 laying around can i do a serious transplant?
And what would i need to make it happen?
My 5 questions for now any and all help appreciated thank you
17 May 2008 14:30 #35 by mlines
Replied by mlines on topic Re:Start up
The lift you are planning means the tyres will fit. But you should look at doing Castor correction as well if it going to be used on the road at all as the steering will be poor with that lift.
The engine will cope but the gearing will be wrong. With 31 inch tyres a lower transfer box ratio would mean it performs better, keeps the engine happier and gives engine braking down hills. It would also preserve your clutch.
"TrialJimny" does replacement gearsets or an SJ Rocklobster box can be fitted.
The driveshafts and CVs joints need looking after - 31 inch tyres will make it easier to break them!
Send me some pictures and I will put them on the website.
  • Got Mud
21 May 2008 21:31 #36 by Got Mud
Replied by Got Mud on topic Re:Start up
"But you should look at doing Castor correction "
You said i will need castor correction how do i go about getting this done and exactly what is it, do u mean like a wheel alignment?
  • Got Mud
21 May 2008 21:45 #37 by Got Mud
PROJECT UPDATE
Latest development an engine change i will be trying a Toyota 1600cc 16 single cam instead of the 1300cc turbo starlet engine
  • Got Mud
21 May 2008 21:48 #38 by Got Mud
Most likely by the end of the year changing out for Toyota axles form a land cruiser :woohoo:
22 May 2008 06:55 #41 by mlines
This sounds like a big build!
Castor correction brings the wheels back into correct vertical alignment with the road. Its the way that the wheels self centre after you have turned a corner.
As you lift the Jimny the axle moves slightly and the correction bushes/arms push it back into place.
Time to create page: 0.157 seconds
