Rear Washer Jet
  • Jamie
13 May 2010 14:37 #3380 by Jamie
Rear Washer Jet was created by Jamie
Does anyone have a drawing showing where the pipe is routed
as when i park on a hill the washer bottle empties itself through
the rear washer jet!!!! I think there is a non return valve or
some sort of check valve in there somewhere, I think it may be in
the rooflining but would just like to check before i start pulling
it to bit's.
Thank's
Jamie
  • Baggy
14 May 2010 05:17 #3382 by Baggy
Replied by Baggy on topic Re:Rear Washer Jet
Mine does this too. post up the solution if you find one.
14 May 2010 05:42 #3383 by mlines
Replied by mlines on topic Re:Rear Washer Jet
Its part number 11 in the picture below - Suzuki Part 38496-61A00. - Probably cheapest to get one from Halfrauds.
I took mine apart a couple of years ago and seem to remember its behind the rear door panel.
  • Jamie
15 May 2010 09:37 #3391 by Jamie
Replied by Jamie on topic Re:Rear Washer Jet
I'll be pulling it to bits shortly and will take some pics
  • ooky_123
16 May 2010 12:49 #3393 by ooky_123
Replied by ooky_123 on topic Re:Rear Washer Jet
Last weekend, I replaced the rear door on our jimny with a spare sourced from ebay.
after removing the lock barrel, the door was a straight swap.
The washer jet mounts through the door via a rubber, and then runs horizontally to the hinge side, and though the flexi connection to the body. it then goes down behind the rear seatbelt spool, and up to the multi plug on the offside rear behind the rear trim panel.
Time to create page: 0.217 seconds
