Killer wobble Everything is shaking
- Dutchjimny
14 Feb 2012 18:42 #33460
by Dutchjimny
Killer wobble Everything is shaking was created by Dutchjimny
hi all,
I know what the deathwobble is around 70kmh but today the death wobble turned into something different i guess.. i was driving 60kmh when the car started shaking the steeringwheel shaked and the gearknob shaked harder than ever i could only brake and drive slow..
The car is an 2000 jimny with the Ora 3" Liftkit
Please help!
Please help!
- Dutchjimny
14 Feb 2012 19:32 #33466
by Dutchjimny
Replied by Dutchjimny on topic Re: Killer wobble Everything is shaking
hmm.. my panhards have rose joints.. maybe the bolts are loosend up?
I cant use the car at all.. In the beginning 500km there were no problems with the lift
- supergaz
14 Feb 2012 19:46 #33476
by supergaz
Replied by supergaz on topic Re: Killer wobble Everything is shaking
Have a close look at all the leading arm bushes, and the track rod ends.
- funkyjimny
- Moderator
- 2004 jimny soft top, factory hardtop, ARB bumper
- Thank you received: 56
14 Feb 2012 19:59 #33480
by funkyjimny
Replied by funkyjimny on topic Re: Killer wobble Everything is shaking
Panhard bushes is my best guess, I had the captive nut on the axle (that the panhard rod bolts to) strip its thread, everything looked fine but I couldnt get faster than 25mph.
Gary
Gary
- darthloachie
15 Feb 2012 08:47 #33505
by darthloachie
Replied by darthloachie on topic Re: Killer wobble Everything is shaking
we had a similar thing with the track rod ends - had to replace all 4
- Adamski
15 Feb 2012 21:31 - 15 Feb 2012 21:32 #33577
by Adamski
I had this exact problem with my KAP panhard rod bushes. The metal collars inside the bushes were too long so the actual bush wasn't doing anything and causing undriveable death wobble. I cut the collars down, tightened everything up and this cured the problem.
Replied by Adamski on topic Re: Killer wobble Everything is shaking
MysticRich wrote: Hi mate ,
I had a similar experience driving along the m62 last yr. I tried ages to sort it changed wheels tyres. My motor has k.a.p springs ect so I contacted darren at k.a.p who knew straight away it was my pan rod bushes so i would start their as i,m sure their all pretty much the same.
Last edit: 15 Feb 2012 21:32 by Adamski.
Time to create page: 0.178 seconds
