Diffs
  • jo king
06 Feb 2012 20:50 #32866 by jo king
Diffs was created by jo king
Can any one tell me if I would be able to fit the a diff housing from an 07 into a 2001 axle,would there be any problems.
  • darthloachie
07 Feb 2012 07:40 #32883 by darthloachie
Replied by darthloachie on topic Re: Diffs
think the ratio is different
  • Monkey
07 Feb 2012 11:30 #32902 by Monkey
Replied by Monkey on topic Re: Diffs
darthloachie wrote: think the ratio is different
Bingo!
98-05 jimny's, the diff ratio is 4.09:1 and 05-current is 4.3:1
Just swap the center's over's, problem solved. ;)
  • jo king
07 Feb 2012 20:33 #32968 by jo king
Replied by jo king on topic Re: Diffs
Thanks monkey. when you say swap the centres I take it the complete diff housing. Are the pinion longer?
would I need to adjust my prop lengths. I myself thinks it will be a straight swap but I would like to be sure.
  • Monkey
08 Feb 2012 12:04 #33010 by Monkey
Take the axle/cv's out, then take the whole 3rd member out, do the same on the other diff and swap them over.
Have you ever taken a diff center out? I can give more info if needed on how to do it...
