Check your tyre pressures!
14 years 9 months ago #32267 by mlines
Our new Jimny drives well, in fact it has been all the way from "Darn Sarf" to Blackpool and also fully laden down to Hamble and the marinas.
However it seemed a bit light on the front end to me, a smidgen of jimny wobble if provoked by the road surface and skittish in a cross wind.
A quick check of the tyre pressures (it was fitted with new tyres just before we bought it) shows it had been inflated to 28 PSI all round, a typical tyre centre trick.
Dropping the fronts to the recommended 23 PSI and topping up the backs to 29 PSI and it drives like a dream (well as much of a dream as a Jimny can manage).
So if you are not happy with the way yours is driving, check the front tyre pressures. They should be at 23 PSI for normal tyres and a tad lower for fat off-road tyres (I run mine at 18-20 PSI)
  • Keefe
14 years 9 months ago - 14 years 9 months ago #32268 by Keefe
Replied by Keefe on topic Re: Check your tyre pressures!
Nice one, I'll try and remember that tip for my Jim Jam. :)
Another tip, get a decent pressure gauge, I have & trust no one.
Had 4 tyres fitted to my car by a pro tyre fitter. Nearly killed myself on the motorway when a group of 'Efniks' swerved into the outside lane directly in front of me but 15 mph slower! :blink:
The tyre fitters' gauge must have been faulty, said he'd put 29 psi in all tyres.
After a pants change, I checked them, approx 8 to10 psi in all of them!!!
You couldn't tell by 'kicking' or 'touch' because they are very low profile tyres.
As you can imagine, the language was quite colourful over the phone! :evil:
Last edit: 14 years 9 months ago by Keefe. Reason: Spulling mesteak ;)
  • wanderinstar
14 years 9 months ago #32271 by wanderinstar
Replied by wanderinstar on topic Re: Check your tyre pressures!
This is a question I was just going to ask. I have 215 x 15 Saharas. So should I have about 22 front and 28 rears?
  • zuki andy
14 years 9 months ago #32276 by zuki andy
Replied by zuki andy on topic Re: Check your tyre pressures!
hi ian, i think you might find 28 psi in the rear a bit to much. if the tyres have got a stiff carcass (ie if it was an extra load van tyre before) you might find it to be a good ride as low as 20psi or even lower. its just a case of trying different pressures and seeing what suits you. i dont carry pasengers and find having front and rear pressures the same suits me. i currently run my 31"tyres at 17-18 psi any harder and the rides to harsh, got the same size tyres on my pajero and run them at 33 psi
  • srcars
14 years 9 months ago #32286 by srcars
Replied by srcars on topic Re: Check your tyre pressures!
I run my 235s @ 18 all round so the CD does'nt jump ;)
  • ShuDuck
14 years 9 months ago #32298 by ShuDuck
Replied by ShuDuck on topic Re: Check your tyre pressures!
I run 20PSI front and rear with 235/75, they wear perfectly even but the roll resistance is ridiculous :lol:
Time to create page: 0.083 seconds
