Rattle behind dashboard solved!
- Chilgrove
25 Jan 2012 21:01 #31860
by Chilgrove
Rattle behind dashboard solved! was created by Chilgrove
Like several others I have had an annoying rattle which I though was coming from behind the dashboard on the passenger side. I could not find anything obvious and started to look further afield as noises can be deceptive.
Down in the passenger footwell on my car, year 2006, there is a plastic cover panel over the speaker. By gently tapping my fingers on the surface I got a rattle type noise so I removed the cover exposing wiring loom near the speaker. I broke the wee plastic clip at the top but it does not seem to matter. I reckon I should have lifted the plastic sill guard first, it seems to unclip easily.
Anyway I carefully bent the wires in the loom away from the plastic cover and lo and behold the noise has stopped.
Couldn't believe it.
Chilgrove
Chilgrove
25 Jan 2012 22:05 - 25 Jan 2012 22:06 #31867
by Halford
Replied by Halford on topic Re: Rattle behind dashboard solved!
good one :ohmy:
guess what I'll be doing in the morning
Last edit: 25 Jan 2012 22:06 by Halford.
- trextr7monkey
25 Jan 2012 22:20 #31868
by trextr7monkey
Replied by trextr7monkey on topic Re: Rattle behind dashboard solved!
Halford I'm no astro physicist but I reckon you are planning on snapping someof those plastic clips off, probably in the passenge footwell area. :ohmy:
atb
Mike
atb
Mike
- darthloachie
26 Jan 2012 07:36 #31877
by darthloachie
sounds like a plan :laugh:
Replied by darthloachie on topic Re: Rattle behind dashboard solved!
trextr7monkey wrote: Halford I'm no astro physicist but I reckon you are planning on snapping someof those plastic clips off, probably in the passenge footwell area. :ohmy:
atb
Mike
Time to create page: 0.142 seconds
