clutch nosie
  • suzuki jimny fella
25 Jan 2012 22:45 #31870 by suzuki jimny fella
Replied by suzuki jimny fella on topic Re: clutch nosie
could be input shaft bearing has eny one had one fail on the gear box or is it a common nosie eny one got a how to for doing the job not that load see only relly her it in the garage
  • 247sniper
26 Jan 2012 06:44 #31873 by 247sniper
Replied by 247sniper on topic Re: clutch nosie
If it was a gearbox bearing you would hear it whilst driving along the road, can you ????
If you can only hear it when stationary and it disappears when the clutch pedal is depressed then it s most Likely your clutch release bearing.
Spray brake cleaner on it to give it a clean then spray a bit of wd40 on it, dot get the wd on the clutch plate though.
See how you get on.....failing that youll have to put up with it or replace it mate.
Steve.
26 Jan 2012 23:31 #31951 by suzuki jimny fella
can not here it on the road so give it a wash and leave it as it is for now hay if it aint broke dont fix it haha B)
  • 247sniper
27 Jan 2012 06:28 #31955 by 247sniper
Yes. Try giving it a wash out with brake cleaner and then spray it with WD40
Steve.
Time to create page: 0.220 seconds
