clutch nosie
- suzuki jimny fella
24 Jan 2012 22:25 #31811
by suzuki jimny fella
clutch nosie was created by suzuki jimny fella
can you help when i lift my clutch up when out of gear at the point of bit i get a nosie is it my trust bearing or input shaft bearing thanks
- 247sniper
25 Jan 2012 06:12 #31820
by 247sniper
Replied by 247sniper on topic Re: clutch nosie
Can you describe the noise, what does it sound like ?
Steve
Steve
- adamatdraycott
25 Jan 2012 07:18 #31824
by adamatdraycott
Replied by adamatdraycott on topic Re: clutch nosie
It sounds like the release bearing.
Comes and goes for me...
Take the small plastic cover off the out side of the bell housing a give it a good hosing out
25 Jan 2012 19:04 #31853
Replied by suzuki jimny fella on topic Re: clutch nosie
hard to discribe mate like a spining nosies when you press clutch back down you can just her the engine then sorry hard to discribe it
- adamatdraycott
25 Jan 2012 20:06 #31858
by adamatdraycott
almost a bird chirping sound?
25 Jan 2012 20:28 #31859
by facade
Replied by facade on topic Re: clutch nosie
If you mean a great whirring swishing noise in neutral with your foot off the pedal, that goes away when the pedal is pressed down, it is a bearing in the gearbox, most likely the input bearing.
Mine does it too.
It also groans/honks from the clutch (I hope, if it isn't I have no idea what it is) if I pull away a bit sharpish, but the clutch is on its last legs: I intend to change it in the Summer.
Mine does it too.
Time to create page: 0.608 seconds
