Changing front wheel bearings
- 4wheelers
19 Apr 2010 17:58 #3179
by 4wheelers
Changing front wheel bearings was created by 4wheelers
Hi all,
I am after some advice. I attempted to change my wheel bearings over the weekend and had no luck shifting the retaining rings. I used the correct tool and a 2 foot length of pipe on the end of a breaker bar! As I had no luck I drowned the area in wd40 and put back together for now. Am planning another stab at it this weekend.
Has anyone else had troubles removing the retaining rings?
- funkyjimny
- Moderator
- 2004 jimny soft top, factory hardtop, ARB bumper
- Thank you received: 56
19 Apr 2010 18:26 #3180
by funkyjimny
Replied by funkyjimny on topic Re:Changing front wheel bearings
Yeah, 4ft length of pipe on the end of a breaker bar did it for me.
Gary
Gary
- 4wheelers
19 Apr 2010 18:44 #3182
by 4wheelers
Replied by 4wheelers on topic Re:Changing front wheel bearings
I am replacing my hubs to the manual type as well this weekend so I was thinking maybe I won't need to be as gentle with the locking rings.
20 Apr 2010 05:40 #3183
Replied by mlines on topic Re:Changing front wheel bearings
Have you bent back the inner edge of the locking ring where it is bent into the key on the shaft? It is bent it to lock it in place and if you have not bent it out then you are fighting the locking tab as well as the tightness of the lonking ring itself
- 4wheelers
20 Apr 2010 18:37 #3197
by 4wheelers
Yes I have bent the tab out. I have had some luck with the passenger side today. The drivers side looks like it has never been off before and there was quite a lot of gunk and growth around the lock ring. Have now drowned it in more wd40 and fingers crossed might budge on the next attempt.
Time to create page: 0.164 seconds
