Suzuki Jimny 2007 VVT with a low range t-case
  • Nivo
21 Jan 2012 17:32 - 21 Jan 2012 17:37 #31495 by Nivo
hey evreyone!
my name is niv and im from israel
im sorry about my bad english. please forgive me =]
so nor for my question
i have jimny 2007 manual and it VVT engine
i want to put on the t-case a kit to upgrade my low range and to put bigger wheels.
do i have to put samurai t-case? or can i put a kit on it that can make that happend?
i want to pot wheels 235\75R15
can some one help me with that please?
and if you know something send me a link please. thx =]
Last edit: 21 Jan 2012 17:37 by Nivo.
  • reaper
21 Jan 2012 17:48 #31497 by reaper
i run those wheels , they dont require a box change
but if you want a new box there are a few options
custom gears for your box
mini lobster (sj 410 box)
rock lobster ( sj 410/413 hybrid)
  • Nivo
21 Jan 2012 17:57 #31499 by Nivo
what do you mean? i dont need to do seomthing about my t-case if i want bigger wheels?
i understand i must because that car wont move. and it's take lot of patrol and i wont pass the 90 KM'
those custom gears. it's only the inside for the t-case that i just need to replace and that it?
  • Nivo
25 Jan 2012 22:29 - 25 Jan 2012 22:30 #31869 by Nivo
are you sure that with that wheels i dont need any change ? only 2 inch lift?
i want 235\75 R15
my jimny is 2007, and have manual gear box.
i have 2.5 inch lift by trail master.
is that all what i need?
i wont burn my clutch off on rocks and so?
Last edit: 25 Jan 2012 22:30 by Nivo.
  • Monkey
26 Jan 2012 03:45 #31872 by Monkey
Hi Nivo,
235/75 R15 tyre's are fine on a jimny with stock gearing, but only of your doing mud or beach work. To correct the gearing for 235's in a late model jimny, this is your only real option.
www.auszookers.com/index.php?name=Forums&file=viewtopic&t=22832
If you were to put a samurai t-case in with the stock VVT gear box, you would end up with a 40% reduction in high range. The late model jimny runs a 1:1 ratio in 5th gear, un-like the early model jimny (00-05 m13a non-vvt) box which has a over drive gear for 5th and 4th gear is a 1:1 ratio.
If you put a early model jimny gear box in, with a samurai t-case, you would end up with a 16% reduction in high. That would mean you would be 4% over gear (perfect for 30x9.5's ;) ) .
I have the same model jimny as you. I have a early model gear box in it now though and i have changed the diff ratio's out to to 4.09. The stock diff ratio's in a vvt jimny are 4.3 and early model jimny's are 4.09 (NOT 4.11), so about 6% difference. I will be running a samurai/sierra t-case with 4.16 low range gear's. These gear's give a 12% reduction in high and 84% in low (?). So in total i will have a 22% reduction in high and about 92% in low. This setup is for 31x10.5 r15 and it's allows me to keep my freeway revs close to stock.
Hope this makes sense!
Andrew
  • Nivo
26 Jan 2012 18:44 #31920 by Nivo
thx for the big comment!! very helpful!
but i still want to try something with my jimny.
i understood that there's a "kit" for the transfer box for jimny with VVT engine.
i'll try to put that. mybe i wont will be needed a samurai t-case
(here in israel it's very expensive :D )
once agian. im sorry about my bad english.
