Jimny Rear Crown Wheel Diameter?
  • supergaz
11 Jan 2012 19:07 #30649 by supergaz
Replied by supergaz on topic Re: Jimny Rear Crown Wheel Diameter?
Thanks Dave
Its the adjusters that I struggled with, how tight the bearings should be. Don't use tipex! It disappears!:blush:
Will get the measurements as soon as my old naff diff is out, maybe I can get a feel how much lash is on the crown wheel and diff within the carrier on that, don't fancy the tapered bearings too tight, they are firm atm.
  • X8GGY
  • Platinum Member
  • Platinum Member
  • but currently AWOL
12 Jan 2012 11:11 - 12 Jan 2012 11:15 #30728 by X8GGY
I leave the bearing clamps in one piece -
www.bits4vits.co.uk/store/x-alt-fitting-...-right/blog_125.html
and label them left and right, place them to one side, strip and rebuild the diff, then slip them back exactly as they were, so no need to reset the bearings... ;)
See the pictures in the linked blog above... and more in this one -
www.bits4vits.co.uk/store/repairing-stea...struct/blog_135.html
Last edit: 12 Jan 2012 11:15 by X8GGY.
The following user(s) said Thank You: supergaz
  • supergaz
12 Jan 2012 15:50 - 12 Jan 2012 15:51 #30741 by supergaz
Haaaaa, I see where I went wrong, the small bolt on top of the bearing can stay in holding the adjuster in place.
I read all of your blogs so I should have known!.
I will just take the bearing caps off my old diff and try them on without loosing the adjustment. And then see if the play is the same.
Thanks Dave, Get to work on the X90 so I can read your blogs!
Last edit: 12 Jan 2012 15:51 by supergaz.
  • supergaz
12 Jan 2012 16:19 #30742 by supergaz
Strange how Daves vitara diff has 3 roll pins and the Jimny doesn't to hold the shafts in the diff.
  • X8GGY
  • Platinum Member
  • Platinum Member
12 Jan 2012 18:47 #30761 by X8GGY
General concensus seems to be that the Vit rear crown wheel is bigger than the Jimny ones, which inevitably descend from the SJ diffs... so no, my LSD won't fit in the Jimny... so will pop it in the X90 then... pictures to follow Gaz ;)
Exactly, leave the adjuster lock plate and bolt in place, and carefully take the two tops off and set aside, then carefully pop them back where they were, job done, no adjustment should be needed...
Dave
  • Monkey
13 Jan 2012 10:03 #30811 by Monkey
Replied by Monkey on topic Re: Jimny Rear Crown Wheel Diameter?
Hi Dave,
I have both front and rear diffs in peaces at the moment after my little diff breakage :lol: :blush:
I can measure the rear PCD ring for you Sunday if no one else get's in before then...? I can't do the front for a few weeks tho...
Time to create page: 1.158 seconds
