Suspension spacers
- w0ut69
09 Jan 2012 19:31 - 09 Jan 2012 19:40 #30400
by w0ut69
Suspension spacers was created by w0ut69
I want to lift my jimny a bit, but is it bad to use suspension spacers?
And does it affect the handling?
And wheel spacers, dus that affect the handling?
Last edit: 09 Jan 2012 19:40 by w0ut69.
- myers647
09 Jan 2012 20:11 #30404
by myers647
Replied by myers647 on topic Re: Suspension spacers
Hi mate I dont think its bad to use spring spacer, but it think it may make the ride a bit stiffer,and less articulation. I went out green laning last week with a jimny on spring spacers and rear re-location brackets and it was fine. I have 32mm wheel spacers and it actually made the handling better because it give it a wider track.
Hope this makes sense mate.
Thanks
James
Thanks
James
- w0ut69
09 Jan 2012 20:23 #30406
by w0ut69
Replied by w0ut69 on topic Re: Suspension spacers
thanks for the info! Mayby you'll see some of these modifications on my car soon.
Wouter
Wouter
- w0ut69
09 Jan 2012 20:31 #30408
by w0ut69
myers647, which wheel spacers do you have? Which brand?
thanks
Wouter
thanks
Wouter
- bari
09 Jan 2012 20:44 #30410
by bari
Replied by bari on topic Re: Suspension spacers
if you apply shock spacers will this inprove you articulation.
- myers647
09 Jan 2012 20:48 #30413
by myers647
Hi mate I have the 32mm Grayson ones. I have found them very good and take seconds to fit.
Thanks
Thanks
Time to create page: 0.170 seconds
