sloppy gear lever
05 Apr 2010 14:48 #3036 by maverick
sloppy gear lever was created by maverick
doing some TLC today, I (doh) decided to grease the gear lever.
a) removed all boots
b) undone the 3 10mm bolts
c) removed gear lever
d) added some grease into pot
re-assmebly but wow is it sloppy - what have i missed?
Jalapeño, IISY?
06 Apr 2010 09:50 #3053 by funkyjimny
Replied by funkyjimny on topic Re:sloppy gear lever
Hi Mav, theres a plastic bush that sits under the gear lever, if you drop it into the gearbox or drop it off the end of the gearstick when removing it'll be very sloppy. I did it in mine but found a spare from another gearbox i had.
Gary
06 Apr 2010 09:53 #3054 by maverick
Replied by maverick on topic Re:sloppy gear lever
Gary - I have both (?think so?) bushes they have little half-hollows cut out ..
I'm off to a brakers in Wrexham tomorrow (courtesy of Kev) to looksee.
Oh, and how do you get the gearbox oil-filler screw out, to top up gerbox (it is an arse when the engine/gearbox in!!
Jalapeño, IISY?
06 Apr 2010 10:02 - 06 Apr 2010 10:07 #3055 by mlines
Replied by mlines on topic Re:sloppy gear lever
You have got me really confused here (and on the other forum where you have posted this question). I cannot see how you can drop anything into the gear box?? The gearbox is "remote", a bit like the old minis (or do you have a non-standad set-up, I though you were running a standard engine/gearbox) It has two rods that run forward from the gear lever to the gear box.
Last edit: 06 Apr 2010 10:07 by mlines.
06 Apr 2010 10:16 #3057 by funkyjimny
yes were both standard boxes, its not so much drop the thing into the box, but drop it below where its supposed to sit, I put mine back together and it was sloppy as hell, it was the bush thing and mate who owns the garage fished it out, stuck it on the stick, and then refitted stick, all working fine.
Gary
06 Apr 2010 10:18 #3058 by maverick
Hi Martin,
That diagram is what i have .. i just dont understand how it can be so sloppy (spoon in rice pudding) since i reassembled it.
I sort of agree with other forum/posts that the slot in the gear stick that is held in/controlled by the "gear control select bolt" (a 12mm bolt with a protruding bit) maybe the cause as the slot is worn, and perhaps the stick/bolt are a pair?
Also, the two bushes (upper/lower) with those round cut outs - are also loose-ish!
Only other moving parts are big round washer for the 3 studs, the springy-thing under that washer, and a shim on top of the upper bubush ... the lower bush sits in the unit.
If there is some other part - it lost?
Brett
Jalapeño, IISY?
Time to create page: 0.105 seconds
